2004 Endeavor - check engine light
Old Feb 11, 2010 | 04:06 PM
jmh1125's Avatar
Default 2004 Endeavor - check engine light
Check engine light code P0135 was the diagnosis by shop. The issue - they said the oxygen sensor is stuck/frozen and they can't remove it. Option - remove manifold and work on the bench to remove the sensor, if that fails, worse case would be to replace manifold and sensors. Question - does this seem reasonable? Suggestions for removing the sensor? What happens if I do nothing? Thanks for any help!
Old Mar 11, 2010 | 03:18 PM
blackrabbit's Avatar
Default check engine light
My wife's '05 endeavor has had check eng. light on twice. Latest was at about 70,200 mi. You might want to check throttle body for carbon buildup. I removed intake hardware to expose throttle body and used CFC throttle body cleaner, spraying with butterfly open. It took care of my problem.
guyjg
Nov 13, 2021 03:27 PM
04 Endeavor
Aug 16, 2013 03:42 PM
Justincredible90
Sep 7, 2012 05:48 PM
pgb205
Jun 4, 2009 10:40 PM
c577
Oct 16, 2007 12:03 AM
