2004 endeavor, shudders around 1200 rpm in 3 and 4th gear
Car has 122000 miles bought it new. When it shudders you can give it a little more gas and it smooths out. It has new plugs, coil packs, valve cv gaskets. All 4 new 02 sensors. No codes are showing. I had a problem like this in 2014. Mechanic told me to replace the crank shaft sensor. Replaced sensor and timing belt along with the 2 other belts.this fixed my shudder problem. This time I Don't no if it's crank sensor or trans. It also has a new camshaft sensor. Car runs fine except for a little shudder in 3 and 4th gear. Any help appreciated. Thanks Glenn
Hey Guys,
Bought a 2004 Endeavor with 152,000 for a stupid good price and it's shuddering as well.
I am getting the dreaded P0303 misfire code.
Changed the plugs and the coils.
What else should I consider?
Any help is much appreciated!
This is my second Endeavor and love them.
SDRaymond
02-01-2007 08:51 AM
