2004 endeavor, shudders around 1200 rpm in 3 and 4th gear
Old Mar 23, 2018 | 10:32 PM
Theolitas's Avatar
Default 2004 endeavor, shudders around 1200 rpm in 3 and 4th gear
Car has 122000 miles bought it new. When it shudders you can give it a little more gas and it smooths out. It has new plugs, coil packs, valve cv gaskets. All 4 new 02 sensors. No codes are showing. I had a problem like this in 2014. Mechanic told me to replace the crank shaft sensor. Replaced sensor and timing belt along with the 2 other belts.this fixed my shudder problem. This time I Don't no if it's crank sensor or trans. It also has a new camshaft sensor. Car runs fine except for a little shudder in 3 and 4th gear. Any help appreciated. Thanks Glenn
Old Jun 4, 2018 | 06:56 PM
Theolitas's Avatar
Default Fixed shudder problem.
Drained transmission and added 5 qt's mitsubishi trans fluid. Shudder went away. Car now shifts fine with no shudder.
Old Jun 28, 2018 | 08:10 PM
Gvzer's Avatar
Hey Guys,
Bought a 2004 Endeavor with 152,000 for a stupid good price and it's shuddering as well.
I am getting the dreaded P0303 misfire code.
Changed the plugs and the coils.
What else should I consider?
Any help is much appreciated!
This is my second Endeavor and love them.
Old Feb 5, 2019 | 10:46 AM
napdan's Avatar
Any updates at all? Im wondering what it was.
Thank you ahead of time.
ttmbam
Sep 22, 2017 01:42 AM
E-clipse
1st Generation
Jan 18, 2011 09:09 PM
FFXLuc
Aug 6, 2006 09:35 PM
venom3230
Jan 12, 2004 08:32 PM
