2006 endeavor timing belt change
Old Sep 16, 2011 | 11:37 AM
frankmanic's Avatar
Default 2006 endeavor timing belt change
I took my 2006 endeavor in to have the timing belt changed this morning including the two tensioners. I was told that i should have the water pump ($60.00) replaced and the actuator ($270.00) for the timing belt replaced. The last couple of weeks I read on this forum and other sources that the endeavor water pumps are pretty good and usually do not have to be replaced when changing the timing belt. I declined to have those changed. The mechanic basically said that it was preventive maintenace " in case it should fail" since the labor invovled in taking everything apart and i would be just paying for the parts - so just curious - is that an upsell? or just duing due dillegence on their part?
Old Oct 2, 2011 | 10:08 AM
aticruz's Avatar
It is common practice to replace the water pump once the timing belt is replaced. It is not an upsell. Also, it is a common practice that every other timing belt replacement, the pulleys, or if preferred only the idler pulley should be done as well.
rgdavis
Sep 22, 2021 05:02 AM
gagan@candgdistributors.ca
Nov 26, 2010 11:59 PM
2006lancer
Jun 21, 2010 01:21 AM
Adamiecjr1
May 23, 2009 11:00 AM
8000RPMS
Aug 30, 2007 05:49 AM
