Air Leak Noise on Drivers Side Door???
Old Oct 30, 2008 | 01:10 PM
missmegan's Avatar
Default Air Leak Noise on Drivers Side Door???
Hi all! I just purchased a new 2008 Endeavor and I've noticed an air leak noise on the drivers side door when I'm driving (even at relatively low speeds). I took it in for warranty service and they completely replaced the weatherstripping seal inside the drivers side door, but it's still making the noise. Anyone else have this issue? What have you done to fix?
Thanks!!
Old Oct 30, 2008 | 03:48 PM
dsm1990gsx's Avatar
Default RE: Air Leak Noise on Drivers Side Door???
It could have a leak around the side mirror, I have seen that a few times but mind you I work on fords. But just an idea.
Old Oct 30, 2008 | 08:30 PM
missmegan's Avatar
It sounds like it's coming from the back end of the door up top ... like if I'm sitting in my drivers seat and turn my head to the left, the top left corner of the door is where it sounds to be coming from.
Old Oct 30, 2008 | 11:46 PM
BrodyGuy's Avatar
have you checked to see that your window is sealing properly when it is rolled up? also is it possible that it is road noise from a roof rack perhaps?
Old Nov 1, 2008 | 07:04 PM
dsm1990gsx's Avatar
Was the car ever in an accident? There is probabaly a slight gap between the door and the body where the weather strip isn't sealing 100%.
Old Nov 6, 2008 | 10:25 AM
BEAT's Avatar
Do you have window side delfectors on your doors? (can you pls take it easy with the colors?)lol.
If you have those thenthey are making those sound. I have those on my car.
Second did you ever left your key in your carand called Triple AAA to open your car?
they used a wedge to open the door?
if so the door has a gap. Even a slight gap of a few centimeters the wind create annoying sounds
Please tell me ASAP so I can help you or take a pics of your car door and post it here
Old Nov 19, 2008 | 07:51 AM
Guz Man's Avatar
i had the same exact issue and the stealership fixed it for me under warrenty
it was the weather strip at the door, wearing out.. they replaced the whole thing for me, and now, not even a faded whistle...
it took them around 3 weeks though to get it, they said it was on "national backorder"... i dont know if it was true or them being lazy @$$es, but anyways... let them check it for u and see
good luck
PittsburghMontero
Aug 25, 2014 12:47 PM
TheRock0720
Nov 12, 2010 12:30 PM
oops129
Nov 2, 2005 06:37 PM
97Eclipse
Dec 3, 2003 04:57 PM
