brake problem...
Old Dec 5, 2008 | 08:48 PM
jac_76's Avatar
Default brake problem...
Has anyone ever had a problem with a brake pedal when the temperature outside is below 15F? The pedal gets hard as a rock and the breaks does not work until I press it for few times.
Old Dec 6, 2008 | 07:21 AM
Manybrews's Avatar
Default RE: brake problem...
probably moisture in the brake booster.... or in the one-way valve on the vacuum supply hose.
Its not completely uncommon. Its not just a mitsubishi issue, either, as that can happen to a LOT of cars.
Old Dec 7, 2008 | 03:55 PM
jac_76's Avatar
thanks for answer Manybrews, I set schedule at dealer.
Old Jan 18, 2009 | 10:52 PM
jac_76's Avatar
After the car taking to the service department at dealer and having the brakes job done (front pads and rotors replaced with bleed braking system) the problem still exists...even better, now the pedal get hard not only after staring the car but also during driving - seems a little dangerous. It happen two times in one day during cold weather. Service department manager says he had never had any experience with such thing. Can somebody help?
Old Jan 19, 2009 | 03:37 PM
Manybrews's Avatar
id recommend replacing the vacuum supply hose for the brake booster. Theeres a valve inside the hose that is probably freezing shut, preventing vacuum from applying the brakes. They brakes WILL still work, but you wont have power assist.
as the temp of the car or the ambient air rises, the issue will disappear.
If its not the hose, its the vacuum diaphragm itself. since thats less likely and more expensive, Id start with the hose. Do NOT use any hose.... get the correct one!
Old Jan 20, 2009 | 08:43 PM
jac_76's Avatar
thanks, its a big help, I'll check with teh dealer
Old Feb 10, 2009 | 07:06 PM
jac_76's Avatar
After visiting different mitsubishi dealer and replacing brake booster, the brakes work great
Old Mar 7, 2019 | 04:01 PM
Diana Andrews's Avatar
Default Brake booster valve obsolete
I've read that it can be home made, but the brake booster valve hose is obsolete and will not be available after market either. Any ideas?
Spiker74
May 24, 2011 06:13 AM
andreitentean
Dec 19, 2010 05:58 PM
LISAM696969
Sep 24, 2009 01:54 AM
raporte
Dec 29, 2008 09:20 PM
montero1
Jul 5, 2007 01:00 AM
