Gold oily coating all over the rear wheel
Old Feb 17, 2014 | 05:23 PM
Garvinder's Avatar
Default Gold oily coating all over the rear wheel
Recently there is an oily sticky coating on one rear wheel, what is this the result of?
Old Feb 19, 2014 | 08:31 PM
TechnoGeek's Avatar
Default Potential Answer
Assuming it was not something you picked up from the road, It can only be Brake fluid or 90 weight oil from the axle. Most likely it is brake fluid.
1st Check the brake fluid level under the hood.
2nd clean it up. Take off the wheel Clean everything especially the entire brake caliper area with Brake cleaner and a stiff brush and wheel with plain soap water or maybe just wipe clean with a rag if its not real bad.
3rd. Look around for any new wet spots.
4th Drive it a few miles, take off the wheel, look all around the brake caliper area look for a new wet spot.
Old Feb 22, 2014 | 07:39 PM
Garvinder's Avatar
Default Cause found
Thanks for the thoughts!
Turns out it was residue from the brake pad as the pad was worn down alot.
bic007
Nov 22, 2014 10:28 AM
Di Blankleider
Jul 9, 2013 08:52 PM
Momoe002
May 29, 2009 04:30 AM
EVO4L
Oct 5, 2008 07:30 AM
kt lex
Mar 24, 2005 08:08 PM
