OEM trailer hitch
Old Apr 25, 2006 | 07:04 PM
payasosalvaje's Avatar
Default OEM trailer hitch
Hello -
Has anyone installed a trailer hitch on an Endeavor. I just got mine (2005) and want to install a Hidden-Hitch® one, it seems fairly easy but I was wondering if anyone has actual experience doing this. Also, does anyone know if the LS Endeavor comes with a pre-wired harness? where would it be? anything to keep in mind?
I certainly would appreciate any comments or concerns.
Juan
Old Jul 1, 2006 | 05:55 PM
TheVerdict's Avatar
Default RE: OEM trailer hitch
i have the factory hitch with the factory pre harned wiring installed by the dealer. weird is the hitch states its a class 2 while the reciever is a class 3.
Old Jul 18, 2006 | 11:13 PM
lovinmud's Avatar
The wire harness is located on the inside, back left floor panel. You will have to remove the flooring aobve the spare tire. Thn to the left on he floor you will see two tie down hooks with eithe 7mm or 9mm bolts. taked those out and i belive a couple of screws. once odone reomve the panel and you should see a wire harnes already there, or just a black box in which you can install a factory harness into. Do ot have the dealer do it, to much money.
daehnomel
Nov 4, 2020 04:59 AM
piper
Aug 13, 2020 01:46 PM
islandrider
Aug 11, 2020 06:07 AM
contourcrazy
Jan 20, 2007 12:39 AM
Andyfoos1
Mar 11, 2006 09:22 PM
