Need Mounting Hardware Info for '15 Outlander OEM Trailer Hitch
Old Nov 14, 2014 | 08:23 PM
daehnomel's Avatar
Red face Need Mounting Hardware Info for '15 Outlander OEM Trailer Hitch
Just got a 2015 Outlander and I wanted the OEM trailer hitch. Bought one off of ebay for a big discount, the catch was that the OEM hitch kit was missing the hardware. The part number for the hitch kit is MZ314710. Does anyone have the measurements / rating of the bolts included in this kit? I know it supposed to come with 4 M12 and 6 M8 bolts, but I'd like to know the length / thread / rating of them if possible so I can buy them before disassembling my bumper.
Hoping someone who recently purchased this same item or who works in a mitsu parts dept can help out. Thanks in advance for the help!
Old Nov 3, 2020 | 08:48 PM
shodown's Avatar
I dont suppose you got any answers to the M8 bolt length?
Old Nov 4, 2020 | 01:44 AM
DibbyDibbyDJ's Avatar
M8 bolts are 4 of 30mm m8x1.25 and nuts with 8 washers and then 6 of 25mm m8x1.25 with washers. The six bolts hold the towbar crossbar on to the back panel, the 4 hold the towbar crossbar to the side brackets.
Old Nov 4, 2020 | 04:59 AM
shodown's Avatar
Thank you for your reply. I probably should have specified, the parts on the end are still bolted on. I just needed the 3 M8 bolts each side where the towbar bolts into the old bumper support spots.
I ended up buying 6x M8 25mm, 6x M8 30mm and 6x M8 40mm just in case. I also bought replacement M12 bolts and all the conical washers as I'd read previously you shouldn't re-use high tensile bolts.
Thanks for confirming thread length tho.
piper
Aug 13, 2020 01:46 PM
islandrider
Aug 11, 2020 06:07 AM
lastexile
Nov 21, 2012 02:19 AM
rgsoundguy
Aug 14, 2008 08:54 PM
payasosalvaje
Jul 18, 2006 11:13 PM
