Remote Signal
Old Aug 22, 2009 | 12:16 PM
dirtys0uthfl1's Avatar
Cool Remote Signal
Where's the best place in the rear of a 2008 Endeavor to get a remote turn on signal for an aftermarket amp? I've taken it from the power outlet in the rear, but it appears to be always on. Any other suggestions?
Old Aug 23, 2009 | 04:56 PM
jason clipse's Avatar
um. take it from the back of ur stereo use the power antenna wire if there is no remote wire.
Old Sep 3, 2009 | 12:23 PM
06Endeavor's Avatar
That depends on what head unit you are using. If you have an aftermarket unit, it should have an signal lead for your amp. That's your best option. I'm not sure if the factory unit has anything that would work. You would have to check the wiring diagram. These can be found at auto sound stores or on the packaging of after market wiring harnesses.
The option suggested in the previous post would work too. There are also switched power items that you can tap into in the fuse box.
Integrating with these newer built in stereos, kinda sucks. Good luck.
n5926g
Mar 17, 2007 11:10 AM
Pajoz
Mar 18, 2005 11:06 AM
Kannif0
Oct 25, 2004 11:42 AM
Flipz
Oct 16, 2004 09:41 PM
sebastian1023
May 16, 2004 09:09 PM
