Sound, Indicator (signal) switch
Old Mar 14, 2005 | 02:31 AM
Pajoz's Avatar
Default Sound, Indicator (signal) switch
It always annoy me when i put my indicator on specially LEFT.. the sound is like short circuit or burning sound. After trying agin it will go, but most of the time the sound is there. Is there someone can help me guys with the same problem? Any input ? Thanks!
My Monty is 96'LS
Old Mar 14, 2005 | 12:39 PM
pc's Avatar
pc
Default RE: Sound, Indicator (signal) switch
The easiest first thing to do is to replace the flasher unit. On my 92 the turn signals and hazard lights are operated with the same unit.You may have separate units. If that does not fix the problem you may just have to trace the problem but you'll need a circuit diagram. I would determine if you have too much load on the turn signal circuit, i.e. added aftermarket lights or if you tied in for other electrical devices spliced into that circuit. If you do, disconnect the added items and see if the problem goes away. If not then comes the hard part, troubleshooting each part of the circuit. The power for the turn signal circuit comes from the battery when the ignition switch is on then goes directly to the flasher unit then to the turn signal switch and then to the turn signals. It's odd the sound only happens on left turn if it's the flasher, that may be a good clue as to where to look. You may want to take it to an auto electric shop where the techs can measure load and determine if you have a short circuit in the system. The burning sound may be just that, burning!
Old Mar 18, 2005 | 11:06 AM
DarkManC's Avatar
Turn signal switch sounds to be your problem Mitsubishi Part# MR277925
2000MontyLtd
May 7, 2011 10:26 PM
Chris_FL
Mar 29, 2011 06:04 PM
fiestataz
Feb 28, 2011 08:46 PM
tjbiker031
Oct 21, 2008 03:06 PM
98Montero
Oct 19, 2008 08:43 PM
