act clutches
Old Feb 7, 2008 | 06:35 PM
5280LANEVO's Avatar
Default RE: act clutches
I bought my evo from a guy that took it to the dealerwhen he burn't out the first clutch,my question is did mitsubishi replace the first clutch with the same one so you get all the same problems or did they make it stronger.
Old Feb 7, 2008 | 06:53 PM
they replace it with a stock one otherwise youll viod your warrenty. the stock clutch is not that bad if you drive the car and not try to race the car all the damn time. my stock clutch lasted 41k and still had plenty of life left on it when I upgraded. I never really launched the car and never went to the track on it
Old Feb 7, 2008 | 06:57 PM
5280LANEVO's Avatar
I haven't launched eather at least now i can focuse on spending money else were.thanks
Old Feb 7, 2008 | 06:58 PM
ORIGINAL: 5280LANEVO
The stock clutch is soft so if you make alot of power it wont hold well but I had every bolt on with my stock clutch with the exception of cams which I added later and my clutch still held on to all those mods for over a year
Old Feb 7, 2008 | 08:45 PM
southside's Avatar
so for a stock evo what style of clutch, flywheel, and pressure plate combo sould i use.
Old Feb 7, 2008 | 09:37 PM
stock clutch is fine
Old Feb 7, 2008 | 10:31 PM
southside's Avatar
ok thanks
Old Feb 9, 2008 | 11:58 PM
Mike21's Avatar
Hey Xtreme, got a quick question about the MB7-HDSS ACT clutch. On the ACT site, it states that the torque capacity is 508. Is that 508 the max capacity at the wheels or crank?
ORIGINAL: XTREME
ORIGINAL: TheEngineer
yea what he said
If you do a search for tranny lockout in the evo section i believe emonz did a nice little write-up one time on exactly what it is and how its caused. But generally the ACT have been notorious for it. On an eclipse the act is fine but for an evo i think exedy and tilton are the best
I have an ACT HDSS clutch with absolutely no lockout issues in the higher rpm's. The lockout will occurif you don't have the clutch pedal adjusted correctly.
Old Feb 10, 2008 | 07:21 AM
i wouldnt even worry about that anyway. 508Tq at the wheels means like 650HP or more unless your on a stroker.
Old Feb 10, 2008 | 11:07 AM
stutinr1's Avatar
any one that wants 2 put out hp from an evo
and is looking for a good clutch
check out the ACT/MB7-ETG6
the 6 puck so you can still slip a lil
