which gauges to get in an evo
Old May 31, 2006 | 05:33 PM
Hamx0r's Avatar
Default which gauges to get in an evo
ok, i am going to get a a-pillar tripod but i dont know what gauges to exactly get but i was think boost/vacuum gauge, air/fuel ratio gauge, and a exhaust gas temperature gauge. Now here is my dilemma is a EGT the same as a AEM wideband 02 sensor or is it different because they both attach to the exhaust and they both are the way to better tune your car. so i was just wondering if they are the same?
Old May 31, 2006 | 07:22 PM
Default RE: which gauges to get in an evo
I got Breddy boost and AEM UEGO that is all , but if I were to get more it would get oil pressureand or EGT
Old Jun 1, 2006 | 01:24 AM
Hamx0r's Avatar
so pretty much the AEM UEGO does the same job as Air/Fuel Ratio gauge.
For Example a Megan racing Air/Fuel Ratio Gauge would be fine:
http://meganracing.com/products/prod...asp?prodid=219
And then all i would need would be a EGT, Boost/Vacuum.
Old Jun 1, 2006 | 01:30 AM
No, ever notice the $200 extra for the UEGO? its because it is real you want to make sure it is a WIDEBAND not a NARROWBAND a\f gauge which you posted a narrowband,
Narrowbands just give you a remote idea
wideband gives you exact digital readings and is the only true way to tune properly
Here is my setup
spyder4g63t
18
Dec 20, 2006 05:42 PM
97gstspyder
Jul 10, 2005 11:28 PM
badass91hatch
Apr 13, 2005 12:32 AM
darkman0127
Sep 25, 2004 06:35 PM
DeJa_Voo
Aug 11, 2003 01:11 AM
