how to reach 11s
sure thing extreme. i'll post the extact number in about a week or so, because right now the evos on a lift, were installing an act clutch. as soon as that's finished, were heading back to my buddies dyno and tunning the cams.
it shouldnt take more then a week, depending on how fast i can get rid of some of the cars in the shop.
ill keep you posted.
do you have cossworths? how much hp did you gain? so i can have an idea.
Gus
Gus
ComposeEvo, Unfortunately Ididn't dyno my Evo before or after installing the Cosworth Cams. My butt dyno tells me there is more power and WORKS claims 20hp - 35hp but I would still like to hear from others as there aren't many Evo's around with Cosworth Cams installed and dynoed yet. How did the ACT clutch install go...mine took forever!!
lol. were done with the act clutch, we finished it today, it was a pain, but ive had worse. Now all we have to do is finish some cars at the shop and we'll have some time off for the dyno.280 cams are alittle harder to tune, but i'll get it running right. i plan to make atleast a 25 hp gain on his car.
I see you run a 12.52, that's fanstatic. i was also curious like emonz to know what did you run on your short (60ft) and final mph. just to know if maybe you could have squeesed some more time out of it. What i recommend is to upgrade your fuel pump, and make your own boost controller, at about 23psi, you should be able to shave that time down jurastically.( use 110 octane when you run on the track. just to be safe, because your leaning out the engine when you flash it)
you could go with an aftermarket B.C but i find the self made one more reliable.
let me know how it goes, and i'll have those dyno reports as soon as i can
Gus
Gus
He doesnt need to run 110 or 116 if he doesnt want to. A flash isnt ungodly lean he is only at about an 11.1 AFR that is fine for 93 or 91 and his flash controlls the boost but its only at like 21PSI I bet. either way I gonna go out on a limb and say he prob. should have done better than a 12.5 with his mods since mod IX's are getting that on cat backs and a flash that is why I am curious to see his 60ft. im thinking his 60fts will be like 1.9-2.0ish range and his traps will be like 115 or something
i doubt his trap was at a 115, being as though all your time is made at the launch in an evo, it's rare to see that high mph running a 12.5. Maybe if he spun his tires it could happen. If it is true, that your mph is that high, at 115, thats easily an 11 second car. or very low 12s depending on your style of driving.
as for the 110 octane, i always recommend it to everyone, in alot of cases it's not needed. but it's always safer when leaning out the engine.Even if it's minimal. you figure you do 5-7 full all gear passes on average at the track, it's for personal reassurance.
Gus
Gus
ORIGINAL: ComposeEvo
ORIGINAL: TheEngineer
I thinkthat is what emonz was getting at is that the car should be running a low 12 to high 11 with the mods he has on it
his car should be easily a low 12 sec car IMO
lol. you just said, exactly what i was thinking, but didn't want to say because i figured it was too blunt. I know exactly your point emonz
I'm sure with practice, he'll make that evo run high 11's. just takes some time.
Gus
P.S let us know what your short was,and trap speed. maybe we can help you shorten that time alittle more.
Gus
Gus
Gus
