MBC or EVC
MBC or EVC
In preparation to get my Evo tuned I'm running into an issue. I'm not sure which type of Boost controller to purchase. Does anybody have opinions on a Manual Boost Controller vs an Electronic Boost controller? I'm not sure which is good and which is bad.
RE: MBC or EVC
Greddy Profec B is AWESOME. A little expensive but always reliable and some even have the digital readout. Some also have presets so you can have one set to Low Boost and one to High and alternate between the 2. MBCs are cheap and simple and most never break. Its upto you!
Im using the Greddy EBC and love it....
RE: MBC or EVC
well its mostly a matter of money vs. convenience. The manual boost controller you have to get out of the car and get under the hood (unless you have some setup that goes into the car.) But most leave it in the engine bay. Also the manual boost controller isnt as accurate as the EBC. However with the EBC you will be spending around $300 more. Both either one will do the trick.
