over boost need reason why
Old Jul 25, 2008 | 07:45 PM
roccu's Avatar
Default over boost need reason why
I have a 05 evo 8 with a PRofec B-spec II boost controler and it is over boosting. It happened one other time and i brought it to someone he fixed it. Itworked but it started agian the controller i turnned off and it is still doin it. I put all the settings as low a they would go still dose it. The only thing i did since it was fixed was remove the tube and the T fitting from the old boost gauge it was connected right to the turbo inlet. Why is over boosting so much a is there anything i can do to fix it. It over 20psi
Old Jul 26, 2008 | 10:35 AM
Default RE: over boost need reason why
make sure the EBC it hooked up properly. stock is 20.5 PSI btw and you will spike 2 psi or so more at first. what levels are you hitting
Old Aug 19, 2008 | 06:27 PM
EVO4L's Avatar
i have the same controller. mine works great. i had a boost spike problem where it would hit high but it would quickly drop to under 10 that was a screw up from the guy that put it in. he forgot to take out a piece of packing that it came with. however with the controller has to do with the settings. use your manual it came with. if u have problems hit me back.
Maximus99
Sep 16, 2017 07:23 PM
Threepk2
Dec 3, 2007 10:18 AM
jpmontero98
Oct 18, 2007 06:30 PM
NubianSithLord
May 24, 2007 07:49 AM
slow420a
Dec 9, 2005 07:14 PM
