p300 code common on upgaded evos?
Old Nov 13, 2007 | 07:23 PM
antox18's Avatar
Default p300 code common on upgaded evos?
Old Nov 14, 2007 | 07:24 AM
Default RE: p300 code common on upgaded evos?
what is the p300 code? Rear o2 or somthing lol cause that one is common yes.
Old Nov 14, 2007 | 02:23 PM
evoracer's Avatar
Yes it is common, it is a random misfire, and there is a reflash available at the dealer (assuming you don't actually have a misfire). Note- if your car is flashed (Dynoflash/Vishnu/Works etc) the reflash from the dealer may return it to stock.
Old Nov 14, 2007 | 05:20 PM
hmm I have never had a random mis on my Evo and I just flashed it for the first tim last june after 2 years of bolt ons. Does that apply to only certain year Evos?
Old Nov 14, 2007 | 05:48 PM
dsm1990gsx's Avatar
ORIGINAL: EMonz57
All obd II cars the dtc numbers are all the same p0300 random mis, then p0301, p0302... ect for cyl misfire.
Old Nov 14, 2007 | 09:15 PM
evoracer's Avatar
I beleive it was more of a problem on the earlier VIII's, 03-04 if I recall correctly. It is a ghost code anyway, no actual problem for the recall except the light being on. I would however reccomend talking ot a good reputable dealer about it and getting the flash done if it applies, that way wou know if the code comes up that you actually have a problem and not just ignore the code assuming it is BS.
Old Nov 15, 2007 | 07:35 AM
ORIGINAL: evoracer
Odd yea I have an 03. I never had that pop up once. my car was bone stock when I bought it. but I guess it doesnt rule out the 1st owner may have had it flashed by mitsu. I bought it with only 12k on it though
tcp
Nov 7, 2008 05:53 PM
EvoPowerMods
Jul 5, 2008 02:13 PM
infamouskillas
Apr 19, 2008 04:17 PM
EMonz57
May 6, 2006 08:51 PM
neogeon
Jan 1, 2006 09:41 PM
