Short Ram Intakes
ORIGINAL: EvoSpeed
But if i were to get that IC setup if i were to change to a 50 trim late i would need new lower IC piping right?
Well i am all stock 2003 evo 8 . I ran it at bristol dyno down in east hartford , CT. put down 244.6hp and 246.3ftq on a dyno jet dyno. So i'm going back down there with just my dejon intake pipe and extreme motor sports filter and adapter to really see if it added power or just gave me that cool turbo sound. I got my lightened perrin crank pulley and weapon r upper and lower i/c pipe kit on the way. When tax return comes in i'm doing . turbo xs 3in turbo back with test pipe , megan turbo header , megan o2 housing , fuel pump and jester tuning stage 2 reflash and turbo xs intercooler that should put me at 300whp easy and yes i'm doing the clutch also. Then likely before summer comes i'll drop a fpgreen turbo , gsc stage 2 cams and injectors and once again another reflash and push for the 400 whp mark. if all goes will i should be able to start on the brakes and suspension.
ya well if you do that i hope u put the suspension in front of the brakes, cuz the brembo's should be enough for now and don't really need to be upgraded, unless your just talking rotors and pads.
wut kinda clutch you gunna get, the exedy twin disc one like emonz has?
Nemesis
May 30, 2007 09:12 PM
martpro21
Oct 21, 2005 05:05 PM
