"Ticking" sound?
Old Jun 4, 2007 | 07:15 PM
Default RE: "Ticking" sound?
Wow..... *silence fills the room*
Old Jun 5, 2007 | 12:29 AM
razvan76's Avatar
Shut up you dummie, why you still talking?? Grow some facial hair, pimple!
Old Jun 5, 2007 | 12:36 AM
Why is it you focus on that so much? Are you a 'late bloomer'?
Not sure what that stuff is on my face in my profile pic... kinda looks like hair... not too sure though
Old May 1, 2012 | 11:11 AM
00_galant's Avatar
As everyone else has said, i too thought of lifter tick judging by what you described bit figured i would post to give you another idea. On my galant i heard what sounded like "cards shuffling" when it was warming up and it turned out to be a loose heat shield around my exhaust, try grabbing a pry bar or something of that nature and put pressure on the heatshield with it running, if the noise stops, tighten it or cut it off as i did.
Old May 25, 2012 | 11:40 AM
weigojmi's Avatar
Wow forgot about this. It doesn't do it any longer...but don't recall what fixed it.
Old Jul 22, 2012 | 10:01 PM
Tobys Galant's Avatar
My engine just recently started ticking too. At first I thought it was my a/c compressor but after listening more closely it seems the ticking is coming from the top of the engine so it could be the lifters. The engine has 200k miles on it so I can understand why its ticking. Its real annoying though. I did switch to full synthetic about 3 or so months ago so I don't know if that has anything to do with it. Afterall, sythetic is slightly thinner than conventional.
Old Nov 3, 2012 | 09:37 PM
Jacsdaman's Avatar
What Octane of fuel are you using? Try running a higher octane of fuel to see if that helps if you aren't running premium already. If that doesn't help maybe do some research on adjusting your valves.
darsco
May 28, 2013 11:30 PM
Vadimus
Dec 7, 2010 11:16 AM
lilywilkin
Jun 1, 2010 01:51 PM
face2daeast
Nov 14, 2006 04:16 PM
Eclipsor
Mar 29, 2006 10:38 PM
