99 engine rock when shift into gear
I have a 99 Galant. Last night I got in the car and put it in reverse and the engine shook violently back and forth. It caused the entire car to "buck." The same happens to a lesser extent when the car is shifted into drive. There is a small increase in RPM when the car is shifted into gear (maybe a 150-200 RPM shift, I'm not sure if that is normal but its something I noticed). The car seems sluggish and it hesitates when accelerating from a complete stop.
This morning the check engine light came on. I had the sensors read and they came up with:
P0705-Transmission Range Sensor
P0715-Turbine Speed Sensor
P0720-Output Speed Sensor
The car is well maintained and I'm using the recommended transmission fuel type. Up until last night the car ran and idled beautifully and the transmission shifted with no noticeable problems.
Any ideas? Any help would be much appreciated.
MrGrnMitsu
04-20-2014 07:57 PM
