'03 Water Temp. Gauge
Old 07-07-2011 | 07:49 PM
aleraiders's Avatar
Default '03 Water Temp. Gauge
My water temp. gauge keeps reading high as soon as i turn on the car (even when its cold and i just start it up on the morning). Do I need to replace the gauge? Wiring? Fuse? Does the O2 sensor have anything to do with that? Because i do need to replace that sensor
Old 07-08-2011 | 07:02 AM
HeadsWillRoll's Avatar
http://www.autometer.com/tech_faq_an...x?sid=1&qid=57
http://www.howstuffinmycarworks.com/...mp_sensor.html
Some further reading there, obviously first check your radiator and coolant but I'm guessing you've done this. There could be air in the system but this would usually cause it to go hot then normal, not just hot.
Its most likely that the temp sensor needs replacing, if the fuse had gone it would read cold all the time, it could be wiring but I doubt it.
qenex
07-04-2013 04:10 PM
Natedogg89
01-29-2008 07:24 AM
darknigh7th
10-27-2007 04:07 AM
wolfman
10-29-2004 07:39 PM
