'08 Galant water leaking on passenger side floor
Old Jul 17, 2011 | 06:03 PM
Kptaylor's Avatar
Default '08 Galant water leaking on passenger side floor
I just discovered yesterday water leaking on passenger side floor of my car. It's coming from behind the dashboard. Also everytime I made a left turn it sounded as of water was hitting something hot or a fan. AC was still working fine and now no air is blowing out at all; not even hot air!! Has anyone experienced this problem and have any idea what's goin on or the fix? I have read about several other model of cars and it being condensation drain pipe or something...
Have discovered that after I turned the AC off for an hr and turned it back on it is back to running at full capacity but still having same leaking problem described before.
Old Jul 18, 2011 | 04:05 PM
AutomediaJoe's Avatar
its a coolant problem, probably from the AC. id do something about it quickly before you ruin your cars interior
Old Jul 25, 2011 | 11:34 PM
Galanthighspeeder's Avatar
Sounds to me like you have a bad leaking heater core..
I had this problem on my 2002 Galant 2.4L, there was coolant water
on the passengers carpet.
Old Jul 26, 2011 | 03:38 AM
redhead2001's Avatar
It's probably the evaporator drain is clogged. The same thing happened to my Galant. You have to find the end underneath the car and unclog it with something. Or take it to the dealership and they should fix it for a small price.
Old Jul 28, 2011 | 02:17 AM
HeadsWillRoll's Avatar
Yes evaporator drain is most likely. You can access it from underneath the car look along the firewall.
Rossperk77
Sep 7, 2014 06:20 AM
mdwooky
Apr 6, 2013 12:58 PM
Galvinized80
Jul 6, 2010 11:27 AM
rsevelin
Jul 28, 2009 10:41 AM
barbalicious
Nov 27, 2006 07:04 PM
