120 AMP fuse off + battery terminal
Old Oct 28, 2008 | 09:46 AM
pung06513's Avatar
Default 120 AMP fuse off + battery terminal
I have a 2000 Galant V6. The 120 AMP fuse and the fuse holderthat is conntectedto the + battery terminal melted. What could possibly be the cause? The alternator tested good.
I couldn't find a universal 120 AMP fuse holder. So I'm thinking aboutputting in a 120 AMP circuit breaker, http://www.powerwerx.com/product.asp?ProdID=35878. Theoreticallyit should work, butam I overlooking anything? What do you guys think?
The dealer was giving me a hard timeabout it and wanted $29for the fuse holder, which is that same cost as the circuit breaker. Plus, with the circuit breakerI'll never have to buy a fuse again or get stranded.
Old Oct 28, 2008 | 11:45 AM
mitsupartsman.com's Avatar
Default RE: 120 AMP fuse off + battery terminal
a really bad short or applying jumper cables the wrong way will melt that fuselink
p/n mr551902 cost you $10.00 shipped
Old Oct 28, 2008 | 12:47 PM
pung06513's Avatar
That's awesome!
Is P/N MR551902 for the 120 AMPfuse or the fuse holder?
And where can I order it online? mitsupartsman.com?
Thanks!
Old Oct 28, 2008 | 05:17 PM
it mounts on top of the battery between the cable and the positive terminal.
Old Oct 29, 2008 | 09:02 AM
pung06513's Avatar
Your picture lookslike adifferent fuseholderand holds a different style of fuse than the one I have. Take a look atmy attach picture and let me know if the one you have will stillwork in my car.
Thanks
[IMG]local://upfiles/18683/55B7F2685B004C2DB2550D8DA32C91D7.jpg[/IMG]
[IMG]local://upfiles/18683/CEEB34CB46DC46C68D642BDF477C115C.jpg[/IMG]
Old Oct 29, 2008 | 09:51 AM
My mistake you need pic number 83701ab which is the fuse and holder
p/n MR452999 cost $15.55 plus shipping.
Old Oct 29, 2008 | 10:28 AM
pung06513's Avatar
That's it. You are the man!!!!!
Thank you.
Old Jul 22, 2010 | 09:22 PM
quartz field's Avatar
my friends neighbor didn't know he had shorted his alternator to ground(the cars frame) with his wrench as he was replacing the belt that drives it. car would start but after a few miles of driving car began to idle funny and battery and brake light would light up and go away as you played around with the gas pedal, but would end up shutting down. he asked me if i could help him why his alternator wasnt charging his battery. i volt meter the battery while running, it was about 11.87v.far below what it should be 13.5-14v.so started to look for what could be the problem.belt was tight, but not to far was the melted fusible link connect to the positive(+) of the battery post. fusible link is 120amp. bought a new one part# MN164188 for $17 fixed the problem.AND THATS ONE REASON WHY YOU DISCONNECT THE NEGATIVE(-) SIDE OF THE BATTERY WHILE WORKING ON YOUR CAR.he said he forgot to do that. car was a 2003 galant 4 cylinder.
Old Jul 24, 2010 | 07:33 PM
lindy8_man's Avatar
Interesting...I wonder if this could be the cause of my dark current that is eating my battery every year... I'll have to look into that one!
Old Aug 7, 2014 | 02:39 PM
nearsky1's Avatar
Default 120A battery terminal
mitsupartsman, where can I order that part you showed in the wiring diagram for that price. the cheapest I've been told was 100.00 for the entire harness from a salvage yard.
waid302
May 8, 2021 01:14 AM
skipperx
Nov 13, 2013 12:38 PM
xOutlanderFiendx
Apr 16, 2013 03:22 PM
ikjadoon
Jul 12, 2011 09:31 AM
steezbro
28
May 10, 2008 09:53 PM
