1996 Galant Starter problem
Old Jan 17, 2011 | 02:45 PM
bsoder's Avatar
Default 1996 Galant Starter problem
Hi,
I am having what I believe is an issue with my starter on my 96 Mitsubishi Galant S. Once every few days when I turn the car on all I get is a click. After 2 or 3 tries it finally starts. The problem has been getting worse and happening more frequently.
I believe the issue is the starter, but I'm having a hard time finding it. I think it is directly behind the engine, under the intake manifold, but I'm not entirely sure.
Has anyone replaced a starter on a 96 Galant? If so, any tips or tricks that might make it easier for me?
Thanks!
Old Jan 18, 2011 | 10:51 PM
jgbrules's Avatar
before you do that, replace the electrical part of the ignition switch. yes, the starter is under the intake, much eaisier to take out from the bottom side. for every 1 starter i have replaced on that model of galant, i replaced a 100 of those switches. just a little FYI.
Old Feb 12, 2011 | 09:50 AM
bakugan's Avatar
Smile 1996 galant 2.4 SOHC car starting issue...
I have the same model and engine trouble , OBD2 flashing EGR , OS2 sensor . i have replace tune up kits and the front oxygen senor 3 months earlier which the old parts looks conditioned since mileage is 100K . starter crank good without slipping gear issue , idling's fine >1k< .
focusing maybe a fuel and vacumm issue ?
p.s update
thanks
Old Feb 13, 2011 | 12:51 PM
bsoder's Avatar
I replaced the battery and the terminal wires at the same time (I should have done them separately maybe to really find out what the problem was), and the problem seems to have gone away.
I believe the problem was the wires, because they were very corroded and rusty. The screw to the negative wire clamp actually rusted off as I was trying to get the battery off.
kcollins812
Jul 3, 2015 11:31 PM
lemke27
Apr 17, 2015 11:57 AM
simply_chai
Feb 16, 2007 04:22 PM
19eclipse91
Aug 26, 2006 03:56 PM
importeclipse18
Jan 23, 2006 09:10 PM
