2.0 Or 2.4 Transmission From A Eclipse
Old Mar 7, 2008 | 12:35 AM
mr.lover21's Avatar
Default 2.0 Or 2.4 Transmission From A Eclipse
I was on This Site And I was Looking Around For A New Transmission and know that the Eclipse Transmission Is Better than the Galant so what i want to know if i can put 1 of these Transmission...
http://market.autopartsfair.com/mits...&year=1996
Old Mar 9, 2008 | 12:11 AM
jgbrules's Avatar
Default RE: 2.0 Or 2.4 Transmission From A Eclipse
hello! i am assuming that your galant is a 1996. if thats correct, you could use the eclipse trans that says 2.4. the 2.0 litre turbo trans wont fit. bolt pattern is different. the 2.0 litre regular trans wont work becausethe 1996 eclipse came with a chrysler 420a engine and chrysler trans. different bolt pattern and electronics. the 1996 eclipse spyder came with a mitsubishi 2.4 litre engine and trans. that trans will work. one thing i do have to tell you is that mitsubishi used the same trans in the galant as well as the eclipse spyder. so i'm not sure why you think the eclipse trans is better, but they are one in the same. before i would buy a used trans online for 1600.00 i would call your closest mitsubishi dealer and ask about the reman trans they offer. you can pick one up for about 2000.00. and it comes with a warranty. spend the extra 400 and get a quality product rather than a used one with no warranty and who knows how many miles. good luck!! greg...
Old Mar 9, 2008 | 02:48 PM
mr.lover21's Avatar
oooo ok thanks
marquesalan
Feb 3, 2007 10:35 PM
Kirral0st97
4th Generation
Oct 27, 2006 09:45 AM
eclipseonjuice
Apr 12, 2006 01:20 AM
fordmanturnedmitz
Oct 28, 2004 10:58 PM
stbmotors
Jul 10, 2004 05:29 AM
