2000 Galant ES won't start
Old Apr 19, 2015 | 02:08 PM
Noah19's Avatar
Default 2000 Galant ES won't start
Yesterday I decided to degrease my engine considering it was very dirty and has probably never been cleaned (I had gotten the car for Christmas). I covered the alternator and the fuse area before doing it. After I squirted it down with the purple cleaner I then rinsed it down with a hose. I let it dry and run for about 15 minutes then took it down the street. As I came back up the street the gas pedal gave out while the car was still running. I heard a pop under my hood. I pulled over and shut my car off. It wouldn't start after that. It will crank but wont start. I let it dry for a day hoping that it was just something that got wet but it's still cranking. I read that I should look at the distributor, but I cannot for the life of me find the distributor on my car! I've looked online at pictures, and I know what one looks like but I don't see one at all. I followed the spark plug wires where they lead to two little boxes, but no distributor. I checked my fuses, it's not them. The spark plugs aren't sparking. I would check the distributor but I can't find it. If you can help me that would be great!
Old Apr 19, 2015 | 02:43 PM
Akzle's Avatar
you have coil packs and an ignition module - not a distributor.
the "little boxes" are probably the ignition module/s, these can be checked with an LED test light or an oscilloscope, it may be them, or it may be the signal input for them (Crank sensor? magneto... something)
obviously start by making sure it's getting the correct signal before deciding they're blown.
Old Apr 19, 2015 | 07:47 PM
Noah19's Avatar
I checked both ignition modules/coils. They're working. I also check all my fuses and those are fine too. I now have no clue what it could be. Could there be an internal fuse somewhere in the engine that's not in the fuse box?
Old Apr 20, 2015 | 12:02 AM
Akzle's Avatar
how did you check them? if they're working, why is there no spark? process of elimination...
also, you'll find fusible links.
Old Apr 20, 2015 | 06:24 PM
Noah19's Avatar
Sore, I meant I had only checked the main fuse box, and those are fine. I was told that there are more fuses then just the ones in the main fuse box. I found another fuse box under my steering wheel, I'll check those fuses out soon. Is there any other possible places for me to look?
Old Apr 20, 2015 | 10:51 PM
Noah19's Avatar
Okay so we just checked the camshaft position sensor and it doesn't seem to be working. I'm gonna my to buy one online for 20 bucks off of amazon to see if that fixes it.
Old Apr 21, 2015 | 08:22 PM
Noah19's Avatar
Its not the camshaft... I still don't know what it is.
Old Apr 22, 2015 | 04:05 AM
Akzle's Avatar
what have you tested
Old Apr 23, 2015 | 09:11 PM
Noah19's Avatar
I've tested the coil packs, and the camshaft position sensor. I cant find an actual picture for my relay/fuse box so I can't tell which relays are which. Also, I'm beginning to think it might be the ECU. I'm also considering it might be the ASD relay, but I can't find out where that relay is. The issue is that there is basically no information on my car online.
Old Apr 24, 2015 | 09:45 PM
Akzle's Avatar
'The issue is
information on my car online.'
haaaaaahahahaha.
a long time ago, i invented these things called books.
Go and buy a haynes workshop manual. Or borrow one from a library. Know what a library is? You could probably find out online...
Hahahahaha. Hell.
