2001 Galant Rear Power Window Problem
Old Mar 28, 2014 | 05:06 PM
Rick333's Avatar
Default 2001 Galant Rear Power Window Problem
Hi,
My 2001 Galant rear windows are not working, so I got new window regulators. I plugged those in to test and the regulator moved up when the switch was engaged, but it won't go down (lower the window). This is true for both of the rear regulators I got. Is there something I'm missing that makes the window go down as well as up? Bad switch working only one direction? But the switch is new too. So....
Thanks!
Old Mar 28, 2014 | 05:12 PM
jkeaton's Avatar
There could be an obstruction tripping out the overload. Have you tried lubricating the tracks?
Old Mar 29, 2014 | 09:39 AM
Rick333's Avatar
Default Okay, thanks
No, I haven't. I will do so and try again. Just to clarify my own words, I tried this with the window regulators not installed, just plugged into the cable. So there is no window attached and the regulator is not yet installed in the door.
Thanks for the suggestion!
DerbyDad03
Jun 26, 2013 09:00 PM
tomopdyke
Oct 2, 2009 10:00 PM
SkeLX69
May 2, 2008 11:48 AM
96montero
Jun 27, 2007 03:19 PM
3000gt1999
Jan 11, 2007 09:12 PM
