2002 Mitsu Galant rear window defroster issue
Old Oct 17, 2007 | 08:07 PM
Mitsufahrer's Avatar
Default 2002 Mitsu Galant rear window defroster issue
The rear defroster on my friend's Mitsu is not fucntioning. The fan works, as well as the a/c, the fuse is good, and the relay is also fine. Yet still he is getting nothing out of the rear defroster. Any insight(s) would be greatly appreciated. Thank you, and I hope everyone has a most splendid evening
Old Oct 29, 2007 | 12:40 PM
dsm1990gsx's Avatar
Default RE: 2002 Mitsu Galant rear window defroster issue
Check to see if you have power to the rear def grid.If thats ok get a test light and follow the grid from side to side, it should be bright at on side and slowly dim. Also see if the grid is broken anywhere on the rear glass, thats most likely your problem.
mikemitsu
Aug 6, 2013 02:38 PM
jrmdir
Oct 16, 2009 02:48 PM
mdupre07
Dec 10, 2007 06:38 PM
montero1
Feb 15, 2007 05:01 PM
SupaChalupa
Jan 26, 2006 12:08 PM
