2002 Spark plug location
Old Mar 16, 2007 | 04:57 PM
hellcat51's Avatar
Default 2002 Spark plug location
Just had plugs and plug wires installed. Thought I'd check them out when I got home to make sure I really did have new wires. Believe it or not, I cannot even see where they are or where the plugs are! Are they under a cover of some sort or just in an out of the way place? I have always changed my own plugs and wires in my older cars but I can not for the life of me find these things. Any help is appreciated. Thanks. Nick.
Old Mar 28, 2007 | 06:24 PM
gvr427's Avatar
Default RE: 2002 Spark plug location
If you actually did replace the spark plugs and wires on your own on your previous cars, then how can you not find where they are on this car? Have you tryed looking in your owners manual?
Old Mar 29, 2007 | 09:49 PM
hellcat51's Avatar
It's easier than you might think. Used to change them in my older Mustangs and Jeeps and used to work on aircraft engines back in the day. Easy to see where they were and the wires/boots that went to them. Not so easy on the Galant. Looks like a stiff straight wire going across 4 posts? Are the plugs under these posts? Nothing on them in the owners manual either.
Old Apr 9, 2007 | 07:14 PM
msteng's Avatar
If you've got the 2.4 liter 4 cyl then they are right on top of the valve cover. I know what you mean though, I was looking to the side at first till DUH. It's not visually obvious as 2 of them are kind of concealed but 2 10 mm bolts give easy access. I changed my plugs yesterday. Very easy. Be glad you don't have a VW...
Old Apr 12, 2007 | 07:21 PM
1991stang's Avatar
You have 2 wires and 2 coil packs. There right on top of your valve cover. Real easy thing to replace but could cost alot of money. how much did you spend for it if you dont mind me askin. I have a 2000 and thinkin of having it done
Old Apr 30, 2007 | 04:41 PM
newmitsugirl's Avatar
i changed my own plugs and wires yesterday. i got 4 Bosch platinum plugs that i had to gap and Bosch wires, (NOTE: THERE ARE ONLY TWO PLUGWIRESTO YOUR CAR...NOT FOUR! SO YOU ONLY NEED ONE BOX OF WIRES BUT FOUR SPARK PLUGS.) it cost about fifty bucks to do it yourself.
Old May 7, 2007 | 02:57 PM
sanjiyan69's Avatar
can anyone post a picture of it?
fdaremi
Mar 15, 2021 11:11 AM
vicicarus
Mar 8, 2014 11:22 AM
djmanm
May 2, 2009 09:04 AM
hellcat51
Apr 2, 2007 03:01 AM
spyder4g63t
Oct 30, 2006 09:07 PM
