2003 Galant ES 2.4L P0300, P0335, P0340
Old Oct 7, 2011 | 01:43 AM
Oranginator91's Avatar
Default 2003 Galant ES 2.4L P0300, P0335, P0340
First time user on here, but I have a 2003 Galant with 218K miles on it and had something interesting happen tonight driving home from work. Car started bucking/jerking a bit. Never did that before. P0300 has been going on for a while but never caused it to act up like this. Timing belt is still good(replaced it around 200k), and ended up replacing the crank sensor too because I didn't put 2 and 2 together because I also replaced the balance shaft belt and didn't realize the gold plate was for the crank sensor(dumbass....). Leveled the plate out and installed a new sensor. Ran good after that. A while later it started missing and showed P0300. Then tonight it bucked and died. I popped open the hood and had a quick look around, and all looked good. I waited about 20 minutes and it started right up and got me home just fine. Before I saw it had P0335 and P0340, I figured it may have been the coils, especially since the car only misfires when it's warm and after it died it wouldn't start until after 20 minutes after it died/cooled down. Now I'm not sure. Could the coils cause this, or do I need to look into new sensors? Coils are factory original, spark plugs have about 5K miles on them and they're NGK Iridium. Any and all help is appreciated!
Old Oct 8, 2011 | 12:16 AM
Update: I installed new ignition coils this morning and at first the car drove just fine, but then after a bit of driving on the way to work, it started misfiring again. I hooked my laptop up to it and it still said P0300, Random/Multiple Misfire, that was the only code it showed. The plug wires are within spec: 2.1 Kilo ohms for the long wire, 2.2 for the short wire. My understanding is that they should NOT exceed 19k ohms. All injectors are within the 13-16 ohm spec.
slavao
Feb 2, 2012 06:55 PM
Shepard69
May 20, 2011 08:50 PM
rascosss
Oct 28, 2010 07:51 AM
05-6G72
Oct 20, 2010 08:51 PM
Rob
Jan 8, 2008 05:58 PM
