93 galant engine troubles
Old Aug 2, 2006 | 11:48 AM
chitty024's Avatar
Default 93 galant engine troubles
I have a 93 galant with the 4g64, it starts and runs like a champ for a bit but when it gets hot it starts stalling and is undriveable. A little ghetto shop told me it was a 600 dollar crank sensor. Anybody have a cheaper conclusion? thanks in advance
- Chad
Old Aug 2, 2006 | 12:54 PM
Default RE: 93 galant engine troubles
Sorry thats bull**** because if it was the sensor then it would not start in the first place. Im willing to bet that this is a leak of some kind. Most probly a vac leak. Are you leaking any fluids? If none of those are the culprit then my money is on a failing fuel pump. Im willing to bet its a vac leak. Do yourself a favor and dont go back to the ghetto place.
Old Aug 2, 2006 | 01:01 PM
chitty024's Avatar
thanks I was wondering how the crank sensor could change from heating up. There are no fluids leaking anywhere the car is in great shape. I will check for vacuum leaks now. What is the best way to check for leaks besides listening? maybe i'll just go buy a roll of vacuum line and replace everything couldn't hurt I guess. Any other ideas if not the vacuum lines?
Old Aug 2, 2006 | 01:10 PM
Fuel pump failure... that would be my least idea. It makes sence to be a leak of some kind because with heat there is expansion and thats when the hole will really start to open up.
I was about to click the OK button and had a little thought. It is possible that one of your plugs or wires could be not functioning 100% when heated. This is also a likely problem. If you want you can replace them.
Old Aug 2, 2006 | 01:20 PM
chitty024's Avatar
thanks alot sebba you have been extremely helpful I will post again once I try these things hopefully they work. thanks again
- Chad
Old Aug 2, 2006 | 01:22 PM
Try the plugs and wires first!
Old Aug 3, 2006 | 12:41 PM
chitty024's Avatar
I wanted to rephrase the question in case it matters I had said it stalls but I guess that could be taken differently. It just totally dies when it gets hot. does this change anything?
thanks
Chad
Old Aug 3, 2006 | 12:44 PM
Nope im still going with a malfunctioning plug or wire.
Old Aug 3, 2006 | 02:48 PM
Manybrews's Avatar
clean your throttle body.
Old Aug 3, 2006 | 03:06 PM
That wouldnt be the problem though. Although cleaning it will always help you.
