95 Galant Transmission Fluid and Suspension Recall
Old Feb 5, 2006 | 02:37 AM
wsia5012's Avatar
Default 95 Galant Transmission Fluid and Suspension Recall
Hi, I have some questions about my 1995 Mitsubishi Galant LS 2.4 SOHC. I had just recently replaced my automatic transmission fluid with a Mobil 1 Synthetic Transmission Oil, I'm just wondering if this is fine or not? And also the whole front suspension of my car was recalled by Mitsubishi 2 years ago, Im also wondering if I need to check them from time to time for wear and tear? or do I need to be worry about this recalled parts? Im afraid it might get brake again. Thanks.
Old Feb 6, 2006 | 01:30 AM
Joel_CA's Avatar
Default RE: 95 Galant Transmission Fluid and Suspension Recall
The recall only involved the replacement of the lower control arm- it did not involve the entire front suspension. The lower control arm ball joint is sealed at the back end which will prevent any debris from getting inside and damaging the ball joint. A periodic inspection would be good and perhas an alignment if necc.
Joel, CA
newoutlanderfan
May 27, 2013 10:47 AM
10101100
Mar 24, 2013 06:22 PM
IanHancock907
Jan 6, 2012 11:54 PM
aganthorp
Dec 23, 2009 06:25 PM
jcasaccio
Jun 6, 2006 06:14 PM
