95 galants sputtering under accelaration
Hey there,
I'm working on this girls 95 galant, with the 16 valve 4 cylinder in it. will doing a "tune up" (new belts, check plugs, change oil) she also mentioned that the car was shaking when ever she would try to "take off". I took the car for a test drive & sure enough when giving the car gas from a stand still it will putter along until it reaches about 15 or 20 mph, then it runs fine. If you are already under way & punch the gas it responds well. after further inspection I notice that the motor will "putter" even when out of gear & at idle it even seem to occaisionally miss. So I checked the plugs & wires - Good, I added some Tranny fluid & cheked the belts. I really don't know what else to check but would really like to get this fixed for her & make me look like a champ, hell I might even get some if I fixer her up good
Lastly the car has 127k miles & never had a timing belt changed. I leaning towards timing belt myself
Any help is welcomed
oh, I also put some 'Seafoam' in her gas to help clean the fuel delivery system - no change.
Thanks,
THomas
Thanks,
THomas
Plug wires - Changed 'em now it runs fine. Well it seems like it's lacking power but I'm comparing it to my Moms '92 with DOC - that car would get it. I've seen 145mph in the '92 several times.
Anyhow thanks for your help guys.
ecco303tke
Jan 30, 2007 04:34 AM
himhotthemnot
Mar 3, 2006 10:26 AM
60, 95, car, changing, check, galant, gears, goong, juvaknight, mifsubishi, mitsubishi, puttering, sputter, sputtering, sputters, studdering, timing
