About to do 120K mile Timing belt change....what else should i change?
Old Aug 26, 2015 | 03:24 PM
XeoNoX's Avatar
Default About to do 120K mile Timing belt change....what else should i change?
Hi, i have a 2006 galant with 120K miles....im about to do the 120K timing belt change, i have following parts
2 Belts
2 Tensioners
1 Idler
1 Water Pump with water pump gasket and water pump gasket sealer/silicone.
i know its kinda of a big job so I was wondering before i give the car and those parts to my mechanic to change...is there anything else that i should look out for or change while i am in the process of changing the belts and water pump?
Old Sep 5, 2015 | 09:45 AM
Copper penny's Avatar
You have probley already done this, But you can Read up on the job and see all what is required. Online or in a Repair Manual.
Old Feb 8, 2020 | 09:50 PM
Amc33vikings's Avatar
May want to do the crankshaft positioning sensor as well. Is right in there with all of that and kind of hard to get to otherwise.
Old Mar 4, 2020 | 11:53 AM
jburney's Avatar
If you are being really thorough, change your serpentine belt and possibly its idler pulley. Definitely inspect the belt for wear, and the idler pulley for play and noise--if either, change it. As for your cam seals, balance shaft seal (if you have one), and front crankshaft seal, most of us wait on the seals until they actually start leaking, but if I were doing this on a car five years older and at 200,000 miles, I would definitely consider changing the seals preemptively. As long as you are working in the area and ordering parts, it may be a good time to replace your valve cover gaskets and your spark tube gaskets. They also start leaking around 100K miles.
Coqui_Mitsubishi
Jun 12, 2014 10:05 PM
Unsullied_Spy
Mar 1, 2012 07:42 PM
ShortyRider
Jan 25, 2012 07:59 PM
guilianno88
Jun 6, 2008 03:51 PM
nate5023
Sep 3, 2004 02:58 AM
