Alignment kit,or not?
Old Mar 20, 2006 | 03:19 AM
Maximus99's Avatar
Default Alignment kit,or not?
Posted: Mon Mar 20, 2006 6:05 am Post subject: alignment kit,or not?
Just got my kit delivered today,for my '99 GTZ V6 Galant -.The Eibach Pro-Kit is sposed to lower it around 1" to 1.5",and I'm wondering with just that much drop,do I need to also get an alignment kit or do I have enough adjustment as is[sm=smiley25.gif] Also,I'll be using the shocks on the car now,until I can get probably KYB AGX's.Will the ones I have b e fine until then? I really havent looked,but I think they are the stock shocks! [sm=feedback.gif][sm=thanx.gif]
Old Mar 23, 2006 | 12:29 PM
acitydweller's Avatar
Default RE: Alignment kit,or not?
your oem shocks will wear out soon.
Ideally you ought to wait until you have the shocks available and do the spring and shock install at once. This saves you the labour cost as the routine would be identical.
Yes, you do need an alignment for any suspension work.
Old Mar 23, 2006 | 04:17 PM
Maximus99's Avatar
ORIGINAL: acitydweller
"you do need an alignment for any suspension work." Of course! I was trying to find KYB AGX's for my 99 Galant V6,& all I've found are GR2's. maybe thats good enough as I dont knowe how much I'll be adjusting the ride,but how does everyone rate the GR2's? As for suspension work to date, all I've done is rear sway bar,front upper shock support
victim619
Aug 16, 2007 01:39 PM
Angelonia
Nov 15, 2006 04:05 AM
99madewell
Nov 3, 2006 05:35 PM
picaxkillr
Jul 28, 2006 11:47 PM
kccobra
Feb 25, 2004 11:32 AM
