Bearing change – front
Old Mar 17, 2010 | 02:32 PM
einar's Avatar
Default Bearing change – front
Is it difficult/time consuming to change the left front bearing? Galant G8, 2l, GLX, year 1998. Any special tools required? Briefly looking/reading in Haynes it does not seem that difficult….. Even though I’m quite used to do maintenance on elderly cars, I’ve never changed the bearing on a front wheel drive – and Galant is also pretty new to me. Any hints highly appreciated. Thanks.
Old Apr 5, 2010 | 11:41 PM
jgbrules's Avatar
pretty simple to do. car needs to be off the ground, remove the brake caliper and rotor, take off the axle nut and move the axle back as far as it can go, there are 4 14mm bolts that hold it to the knuckle, take those out and it will fall out.
Dafatboy
Jul 14, 2015 06:06 PM
Justincredible90
Sep 17, 2013 01:47 PM
eclipsegs99
Feb 6, 2009 03:28 PM
lovinmrv
Dec 30, 2008 09:21 PM
lloydjv
Mar 26, 2007 03:36 AM
