A/C low pressure line stem broken
Old Feb 6, 2012 | 03:23 PM
scalemechanic's Avatar
Default A/C low pressure line stem broken
I have a 2001 Galant that has an A/C low pressure valve stem broken off. I actually accidently broke it off while trying to remove a headlight bulb plug (another post).
Anyway, i would like to know the best way to handle this problem. As i see it i have two options. 1. Either i or someone else solder it back on or 2. Go to the junkyard and for 20 or 25 dollars buy a good used line.
On my first option, i've been told it's NOT EASY to solder aluminum parts together, especially a line that will be under pressure. Any thoughts??
On my second option, it SEEMS fairly easy to remove this line, but i wonder if i'll need new seals, etc. when i install the used replacement so it doesn't leak. Any thoughts??
Hopefully someone experianced in this area will come up with a good solution. Thanks
Old Feb 6, 2012 | 10:35 PM
mxmikie's Avatar
Go to the junkyard and for 20 or 25 dollars buy a good used line. need new seals
newoutlanderfan
Aug 20, 2013 06:47 AM
drakerr
Jan 20, 2013 03:42 PM
Skiddy
Mar 4, 2009 11:09 PM
Skiddy
Nov 26, 2008 08:41 PM
dksnj
Jan 2, 2007 12:41 AM
