Can I put 17" rims on 01 Galant w/out any mods?
Old Apr 12, 2005 | 06:46 PM
toicy4ya's Avatar
Default Can I put 17" rims on 01 Galant w/out any mods?
Sup Guys
I'm looking to purchase a 2000-01 Galant and want to thow some Chrome 17's or possibly 18's on, my question is would I need to modify the suspension in order to do this? or can I just throw em on? Im also looking into dropping it. Can I get some feedback from guys who actually have this type of setup and any problems you might have had with it?
Thanks
Old Apr 13, 2005 | 06:19 AM
wicked_outlander's Avatar
Default RE: Can I put 17" rims on 01 Galant w/out any mods?
ORIGINAL: toicy4ya
Sup Guys
Thanks
yah be ayyte w/ 18's w/ out suspension mods. now when u' drop it....u' need to modify your fender, and u' need a spacer.
Old Apr 13, 2005 | 10:42 AM
toicy4ya's Avatar
What do you mean by "modify your fender"? what's a spacer? How much does it cost? Is it something that I can install?
Thanks
Old Apr 14, 2005 | 02:52 PM
you need to get a wide body fender ( cosmetic ) for your gallant, then a spacer is to space out your wheel.....in order to freely steer a wide wheels.
Old Apr 14, 2005 | 02:55 PM
check w/ your local performance shops, or shop on line. ( got one down below, check it...)
eibach springs / wheel spacer
Old Apr 16, 2005 | 04:39 AM
Prophet's Avatar
You can fit 19's without modifing your fender if your run a proper off set and width......
17's will fit with no problem I am running 18's with no problem and this next show season I will be running 19's.
Old May 12, 2005 | 03:14 PM
maverick091284's Avatar
aiight u can use 18s if u want but the tires has to be 215. or if u go 17s thrown in 225 tires. if the rim offset isnt big, no modification is needed. i have 215/45/17 on and rides fine.
Old May 24, 2005 | 11:44 AM
strapping young lad's Avatar
which alloys would you recommend then?
the 19's im on about now.
Old May 24, 2005 | 05:02 PM
Prophet's Avatar
ORIGINAL: maverick091284
I am running 225/40 series with no rubbing. You have to know the correct off set and width.
Leo Lopez
Mar 21, 2014 12:35 PM
nyc95gst
Jan 13, 2007 07:34 PM
micahman
Jun 5, 2006 01:56 PM
WickedxCurves
Oct 18, 2005 06:51 AM
98EcLiPsEgS
Mar 17, 2004 05:25 PM
