engine or gearbox noise
Old Oct 30, 2004 | 02:30 PM
ianstoke's Avatar
Default engine or gearbox noise
ok i am new and only had my 1998 galant 2.5 a week and its making a noise , when pulling off in 1st gear it sounds like a dry rumbling sound coming from the engine , has i depress the clutch it stopes then into 2nd and the dry rumbling startes again once into 5th its silent but if i hit the gas i can hear it again but not has loud.
please don`t say its going to cost lots of money
Old Oct 30, 2004 | 05:53 PM
1398spdr's Avatar
Default RE: engine or gearbox noise
check the oil...........
Old Oct 31, 2004 | 04:48 AM
ianstoke's Avatar
Thanks i have checked the engine oil and thats fine and will take it a garage tomorrow and get the gearbox oil checked, is it worth replacing the gearbox oil with some kind of special oil ?
Old Oct 31, 2004 | 04:46 PM
1398spdr's Avatar
u mean tranny fluid????? if so then GM Syncromesh is best...........
Old Nov 5, 2004 | 06:38 PM
legnum nick's Avatar
ianstoke - mine does the same thing. I haven't worked out yet what it is. I changed the gearbox oil, but no change. I am thinking it is either the gearbox input shaft or clutch release bearing. I am hoping the release bearing, 'cause it will be much more simple to fix!!
Old Nov 6, 2004 | 02:23 PM
ianstoke's Avatar
NICK- i took mine a garage today he had a test drive and said it sounds like the needle bearings in the gearbox and that i would need a new gearbox, i thought of having to gearbox fluid drained, adding fully synthetic and molyslip G but if that does not at least quite it down a little then then i would not think its the gearbox and go along with your idea thats its a clutch problem. let me know if you get yours sorted out cause that noise is driving me mad. ian
Old Nov 17, 2004 | 06:24 PM
Will do. But I'm hoping I won't have to for a while - no funds available for a few months!
stolizino
Sep 13, 2004 03:24 PM
berdugo
Jul 6, 2004 01:19 AM
A1Syd
Jan 30, 2004 08:13 PM
Offroad Monkey
Sep 18, 2003 03:55 AM
