engine shuts off after a while ????
Old Feb 18, 2006 | 10:12 AM
oriental_express's Avatar
Default engine shuts off after a while ????
hi there guys
My pops has a galant GLSI 1990
when engine is hot or running after a while , it just stop , engine shuts off.
When the engine cools down then Im able to get the engine running again, and the cycle starts again.
I changed the ignition coil but that hasnt helped.
any ideas guys?
thanks for replys
Old Feb 18, 2006 | 05:53 PM
plucky's Avatar
Default RE: engine shuts off after a while ????
hii had the same model with the 2.0cc engine that sounds like your pops is doing the same as mine did.i could drive a long sometimes it would cut out then restart (this was quite violent) and sometimes it would just cut out after about 15-20 mins it would start ok.this did get to do this more and more.i turned out to be a capasitor in the E.C.U. since then i have heared of others doing the same.my main mitsubishi dealer could not find the fault it was only trial and error hope this helps and good luck pete
Old Mar 3, 2006 | 10:20 AM
slowgalant's Avatar
borrow an ecu from a friend and check to see if it works before you go out and buy one
Docsanjo24
Mar 5, 2020 04:58 AM
evrchanging-ecl
Jul 2, 2015 11:09 AM
1997gsstock
Mar 4, 2010 07:41 PM
johnyredd99
Jan 30, 2008 07:00 AM
Kaeslice
Feb 15, 2005 01:26 PM
