fuel trim code and alt belt problems
Old Aug 30, 2006 | 01:04 PM
DanD's Avatar
Default fuel trim code and alt belt problems
Really did try a search. Just aquired a '98 Galant 4cyl. auto 100K miles. It's throwng a PO170 code (fuel trim) which from what I can tell is the MAF, an O2 sensor, or a vacuum leak. It causes a hesitation when accelerating when bad but it's intermittant and so I'm leaning away from a vacuum leak. Anyone have an idea? Also, it keeps munching the alternator/water pump belt. The P/S pump belt is fine. Sounds like the crank/harmonic balancer pulley is bad about coming apart on these cars. Can't see any movement when running but can't see anything else either. How do you tell? Alt turns freely but I guess it could be bad. Thanks in advance.
marx88
Jun 30, 2011 03:54 PM
johnyredd99
Aug 4, 2010 12:30 AM
diamond
Jul 29, 2010 04:16 AM
flunnky
Feb 18, 2007 02:25 AM
keithscianna
Jan 14, 2007 11:43 AM
