Galant 2000: Timing Belt + Clyinder Block Case Assy
Old Apr 13, 2006 | 01:40 AM
uiucgalant's Avatar
Default Galant 2000: Timing Belt + Clyinder Block Case Assy
I have a 2000 Galant ES. The timing belt got broken at high speed (arnd 75 mph). I took the car to the dealer and he told me that a few (lot!) things needed to be replaced:
Timing Belt
Case Assy, cylinder Block FR (Fuel Pump ??)
Water Pump
Adjuster, Timing Belt Tensioner
Belt, Valve Timing
Belt, Balancer Timing
Sprocket, Crankshaft Balancer Shaft Drive
Liquid Gasket, Eng
Gasket, Eng Fr Case
Does this mean that the car wil be up and running...or is there still a chance that something else might have gone wrong with the engine ?
The dealer also told me that it takes a whole lot of labor time (And hence money) to open up the cylinder head and see if anything else might be wrong?
Thanks
Old Aug 21, 2006 | 07:48 AM
uninvited_2000's Avatar
Default RE: Galant 2000: Timing Belt + Clyinder Block Case Assy
I thought that he told you many things
wrongs. Personally i dont believe all of it need to be changed.
Is I4 or V6 engine ?
atherts
Dec 7, 2009 11:54 AM
edgar214
Feb 5, 2009 08:19 PM
rjr234
Dec 11, 2008 09:35 PM
CO 3000GT
Aug 14, 2006 06:07 PM
ttenn
Jun 10, 2006 01:45 AM
