Dead clyinder #3
Old Nov 22, 2008 | 08:03 PM
rjr234's Avatar
Default Dead clyinder #3
Just bought a 91 3000gt from a tow company, nice car but # 3 clyinder has no compression , does any one know how to to check if its the valves are bent or the problem is in the piston .
Old Nov 30, 2008 | 11:16 AM
BrianWSNC's Avatar
Default RE: Dead clyinder #3
three things make an engine run,
1. compression
2. spark
3. fuel
Run a compression check on #3 first. 120 psi and up should be the range. probably much more because it's a high compression engine
If you can't run compression... and easy way it to remove the main coil lead, so the engine will not run... then turn the engine over and listen to it. If you have no compresison on one cylinder you will notice a skip in the cranking noise. ruur ruur ruur ahhh, ruurr ruur ruur.. something like that. (ok not the best example but I am trying!)
If that is over your knowledge.. just take it to a shop and let them diag it for you. go from there...
PS. let us know what you find!
Old Dec 7, 2008 | 04:40 PM
rjr234's Avatar
I took it to a repair shop, it has a bent ex valve causing the problem , they want $900.00 to remove the head and fix the valve, Is the head really that hard to remove?
Old Dec 7, 2008 | 08:23 PM
kweef's Avatar
no but when a shop diagnoses a car it costs money so ur lookin at prolly an hour to diagnose the car, then u have all the parts that will need to be replaced, ur valve costs money, ur new gasket costs money and id imagine the shop gets around $100/ hr...it adds up very quickly
Old Dec 8, 2008 | 07:58 PM
BrianWSNC's Avatar
900.00 to do a valve job on a twin cam v6 engine? That's a good price for this day and age of repair. The guy I bought my 300gt from just had the timing belt replaced, and a tune up. Bill was $1,400.00 (tensioners and water pump is included with Timing belt replacement)
Old Dec 9, 2008 | 11:29 AM
rjr234's Avatar
The $900 is just to remove and fix the one or two bent valves , which is all it really need to fix the problem , thou shops are hurting now and I have got prices for a lot less now.
Old Dec 11, 2008 | 09:35 PM
rjr234's Avatar
Just had the head fixed, one new ex valve, $50.00, new head gasket $38.00 , paid a guy to fix ,mobil mechanic $150.00 to remove and replace , runs like new now.
KF97diamonte
May 5, 2010 01:38 PM
uiucgalant
Aug 21, 2006 07:48 AM
darklibra83
May 30, 2005 12:53 AM
onsse
Mar 18, 2005 10:54 AM
jscopus
Oct 28, 2004 04:06 PM
