Hardwired Radar Detector - Which Wires?
Old Nov 20, 2005 | 09:34 PM
rganders315's Avatar
Default Hardwired Radar Detector - Which Wires?
Does anyone know which wires would be the best to use when hardwiring a radar detector into my new Galant? I had one in my last car, in which I simply used an exising fuse which I wrapped the wire around... But if I go that route, I'm not sure which fuse to use either. Any help you can give would be appreciated.
Thanks,
Old Nov 20, 2005 | 10:29 PM
Default RE: Hardwired Radar Detector - Which Wires?
Sorry, Guess I should say that it is a 2005 Galant GTS.
Thanks
Old Dec 3, 2005 | 04:14 AM
So I went and played with it myself until I found a good fuse to use. Ended up using the cigarette lighter adapter fuse. Once I get a haynes (or something like it) I will use one of the wires, so it dosent us the fuse box. I just think it would look better.
Hope this helps the 3rd 9th Gen Galant that joins LOL
Old Dec 23, 2005 | 10:30 PM
phusion's Avatar
You are going to be neeing a ground for the detector. So from the dash there is going to be the (+) and (-) wires, but internally in the dash there may only be one running to the (+).
budh
May 28, 2007 10:14 AM
iamabadperson777
Apr 6, 2007 02:26 AM
imapirate30
Dec 23, 2006 01:38 AM
david76008
Aug 2, 2006 04:17 AM
j0hn08
Jun 25, 2004 11:29 AM
