Just changed brakes and rotors...
Old Apr 28, 2010 | 11:19 AM
weigojmi's Avatar
Default Just changed brakes and rotors...
And was hoping someone could clarify a couple things:
1) Instead of long caliper slide bolts, there were only about 1 inch long bolts in the slides. Didn't see mention of this anywhere. Needles to say I didn't (re)grease them.
2) There was a thin piece of metal (shim?) in each caliper assembly that was basically loose when I took the assembly off. What is this for? I placed it back against the piston but I'm not confident it stayed there.
Thanks.
Old May 9, 2010 | 08:12 PM
mik543's Avatar
Not sure if its what your talking about but I just did my brakes as well and found a thin piece of metal as well. It ended up being a piece of my old brake pad. Both sides had the same thing. Took it into advanced auto and thats where I got the info. My slide pins are short as well but I DID regrease
msport_2_outlander
Jan 9, 2015 07:30 AM
gbrown
Jan 14, 2010 03:50 AM
needsagst98
Aug 16, 2008 09:50 AM
Khaz
May 25, 2008 03:41 PM
azt021
Feb 28, 2008 06:22 PM
