Knock after timing belt replacement
Old Feb 14, 2004 | 09:24 PM
cookiefan's Avatar
Default Knock after timing belt replacement
I have a 1990 galant 2.0 Liter SOHC. I replaced both A and B timing belts, tensioners, water pump, front motor mount and valve cover gasket. I lined up all the timing marks andchecked that the silent shaft was in the correct position. The car started and ran fine with no vibrations. However, I now havewhat seems to sound like a valve knock. Did I miss something or was there something else that I should have done? I am stumped.
Old Feb 25, 2004 | 11:36 AM
kccobra's Avatar
Does it seem to have the same power? Is your distibutor marks on the same Marks as they where before? Might have jumped a tooth oryour motor is pinging.
njoehow246
Mar 30, 2015 05:00 PM
boostedmuscle22
May 6, 2012 02:06 PM
Randys
Aug 22, 2011 12:02 AM
dott
Jun 24, 2009 05:36 PM
Jeffb1
Oct 3, 2005 02:44 PM
