wont start after timing belt and cylinder heads replacement
Old Apr 26, 2014 | 06:03 PM
njoehow246's Avatar
Default wont start after timing belt and cylinder heads replacement
Just replaced the timing belt on my 2000 mitsubishi montero 3.0 timing marks are dead on number 1 piston is up, firing order is right but it still won't start, its trying but no go and it cranks normal then it like drags while cranking then cranks normal again ive replaced both cylinder heads also due to bent valves need help im stumped any advise would be appreciated thanks
Old Apr 26, 2014 | 07:02 PM
jkeaton's Avatar
So, I'm taking it the timing belt snapped and wreaked holy hell on the engine?
Old Apr 27, 2014 | 09:56 AM
njoehow246's Avatar
Yes the former owner was driving it and the belt broke and trashed all the valves, she then called me to fix it I quoated her a price she didnt want to fix it I offered her $500.00 cash for the truck and she sold it to me I then replaced the heads and timing belt and here I am, havent worked on too many mitsubishi 3.0 hoping someone here can hrlp me figure this issue out
Old Apr 28, 2014 | 04:27 AM
Akzle's Avatar
what are the compression readings
Old Apr 29, 2014 | 04:23 AM
njoehow246's Avatar
I haven't checked the compression when I turn it over manually I can hear and feel it has compression I will check it, is it possible I have number 1 piston on the exhust stroke? If I remove the timing brlt and turn the crankshaft 360 to the mark again would that put it on the compression stroke, someone told me the marks can be lined up and it can still be "out of phase"? Anyone know if this is correct?
Old May 15, 2014 | 07:02 AM
2001Mitch3.5XS's Avatar
yes, remove the belt and rotate 360 then try it.
Old May 16, 2014 | 09:39 AM
njoehow246's Avatar
Ok I removed the belt and rotated the crack 360 back to the mark it is crancking better but still wont start, still dragging somewhat, im smelling gas real strong when cranking but no visible fuel leaks, im wondering if the injector seals could be leaking? And could that keep it from starting? Anyone, anyone? ?
Old Mar 24, 2015 | 11:46 AM
njoehow246's Avatar
Default needs help 00 mitsubishi montero still won't start
Ok update ive removed the timing belt and found the cams were 180 out so I put them back in time and it cranks much better it has spark then I found it had no fuel pressure, so I dropped the tank and replaced the pump now it's getting fuel when cranking but the pressure seems kinda weak still might have a clogged fuel filter, but it still won't start, guys im beating my head against the wall trying to get this truck running, could the fuel pressure regulator keep the truck ftom starting? Please help
Old Mar 30, 2015 | 05:00 PM
njoehow246's Avatar
Default got it running
Omg I finally figured it out I was getting code po340 so I removed the drivers side cam gear which has the cam sensor plate ring bolted to the back of the cam gear and it was bent so I replaced it and she started right away im so relieved I finally got it running so happy hope this help if ahyone else is having the same problem, thanks for all you help guys!
dott
Jun 24, 2009 05:36 PM
Wi_Fibre
Jan 16, 2008 12:17 PM
8000RPMS
Mar 7, 2007 04:02 PM
Jeffb1
Oct 3, 2005 02:44 PM
cookiefan
Feb 25, 2004 11:36 AM
