Looking for Expansion Valve Joint!
Old May 21, 2014 | 10:13 PM
KerryH's Avatar
Default Looking for Expansion Valve Joint!
2004 Galant ES. I'm desperately looking for the Aluminum block that goes between the expansion valve and the high and low pressure lines. It's called the Expansion Valve Joint.Looking for Expansion Valve Joint!-photo.jpg
Old May 22, 2014 | 02:22 PM
KerryH's Avatar
This is NOT the expansion valve. This block does not have a part # through the dealership. I spent 4 hours there yesterday. This is the block that goes between the expansion vlave and where the lines hook up....
Old May 31, 2014 | 05:42 AM
Mathularan's Avatar
Do you have the part at hand? or can you at least draw it? I'm searching for it but cant exactly pin point it, I'm looking through different service manuals to try and find it.
Old Jun 1, 2014 | 05:13 AM
KerryH's Avatar
It's not shown in any service manual. I was told by dealership that the only way to acquire the part is to buy the complete A/C Heater unit that includes the Heater Core, the Blower Motor the AC Core etc. I'll post some more pictures later. The only way I found the name the of the part was on a website that diagramed out how to remove the dashboard. They listed it as the Expansion Valve Joint. It can be removed via the engine compartment through the fire wall. The expansion valve can only be removed by pulling the dashboard.
Old Jun 1, 2014 | 10:06 AM
Hon450's Avatar
Try a junkyard.
Old Jun 1, 2014 | 09:05 PM
mxmikie's Avatar
jrb1and2
Jun 14, 2021 11:14 AM
centerline
4th Generation
Apr 27, 2021 12:26 AM
Idaho Spyder
Aug 18, 2013 04:43 PM
john12345
Jan 1, 2010 04:00 PM
4Grim
May 31, 2009 09:09 PM
