missing screw on throttle body
Old Jan 14, 2006 | 05:30 PM
skitzoid20's Avatar
Default missing screw on throttle body
I have 2001 Galant ES 2.4L 4 CYL and when it is warmed up when I stop at a light the car idles low and the oil light flickers. I have checked the other posts on here and else where and I have replaced the spark plugs and wires. Checked the pcv and it is getting vaccum and I was getting ready to tackle cleaning the the throttle body when I noticed there is a hole where there should be a screw and I was wondering what it actually goes to and if it could be part of the cause. I was reading post talking about the idle adjust screw on 1g/2g galants disappering and this being a problem. Any information would be great.
photo of is also at http://www.geocities.com/joe8500089/question.jpg
[IMG]local://upfiles/5260/0DC72820D78144979D6EE788BEC0CF01.jpg[/IMG]
Old Jan 18, 2006 | 07:02 PM
skitzoid20's Avatar
Default RE: missing screw on throttle body
Well as far as I can tell it is not needed and in several pictures in the haynes manual it is gone as well but I am still having the same issue of the low idle. At this point I am going to take it to a shop and see if I can get the idle adjusted
Old Jan 23, 2006 | 02:42 AM
skitzoid20's Avatar
I ended up replacing the oil pressure sending unit and changing the oil from 5-30 to 10-30 and that seemed to fix it
hawwk11
Feb 9, 2008 01:14 PM
chico_da_man
Oct 23, 2007 07:49 PM
zontarh
Jun 13, 2007 02:08 PM
estraw
Feb 25, 2007 12:48 AM
97GSpower
Dec 10, 2006 03:08 AM
