oil leak from a distributor cap
Old Sep 5, 2008 | 09:15 AM
klexgs's Avatar
Default oil leak from a distributor cap
hey guys, my 98 galant 4g64is leaking oil from the distributor cap. What could it be? Thanks in advance for your replies.
Old Sep 6, 2008 | 05:16 PM
dsm1990gsx's Avatar
Default RE: oil leak from a distributor cap
Replace the distributor o-ring.
Old Apr 24, 2010 | 07:17 AM
derelectric's Avatar
I have this same problem on my 98 galant 4cyl. Did you fix yours?
Old Apr 26, 2010 | 11:55 PM
jgbrules's Avatar
its not comming from the cap guys. there is a oring on the distributor housing that goes into the head. not very expensive. have to remove the distributor, take off the o ring and install the new one. not a hard job. just put some grease or oil on the new oring before u reinstall, could tear if you dont. good luck!!
Old Oct 13, 2011 | 05:01 PM
agregano's Avatar
Exclamation galant oil leak
My 1995 has an oil leak. There is always oil if i wipe my finger under the distributor cap and along the surface it connects to. any ideas?
Old Nov 9, 2011 | 09:55 PM
kenball1980's Avatar
I have a 98 Galant ES too, and I think I have a leaky disributer o ring too. Although I've never actually seen it leak, or seen spots of oil on the ground, there is sludge on the top of the tranny right below where the disributer sits. I replaced one on my Camry, it's simple, but I think there is an internal o ring as well?
TheRock0720
Nov 12, 2010 12:30 PM
willdue
May 30, 2007 11:27 PM
blamesociety
Nov 2, 2006 08:45 PM
paintballproam
May 20, 2006 09:37 PM
2001EclipseGTnub
1st Generation
Jan 16, 2006 10:44 PM
